yellow77
I hate to post the same question on more than one forum, but:
I was checking the caster/camber/and toe settings on the 77 against the factory assembly manual, and I came up with 2.5 degrees caster on the right and 1.6 degrees on the left. For audit control GM recommended both sides to be within 0.5 degrees of each other.
I have been toying with the idea of removing either a 0.030 or 0.060 shim from the rear bolt for the left upper A arm which would move the top ball joint forwards slightly thus increasing the caster. I realize this will also make a small change to the camber, and a tiny change to the toe, but I would like the straight line stability to improve and was wondering if this 1 degree difference in caster was affecting anything.
Anybody have any suggestions?
Cheers all
Richard
Cheers all
Richard
