Steering Wheel Feedback
misterKTM
colton, oregon, usa
'93 Black 6 Speed
I've noticed my vette gives a lot of steering wheel feedback in the corners of rough roads - compared to my f-bodies. It also almost seems like it 'walks' a little in the corner when there is a ripple, or bumps through the corner. I've taken a look at the suspension and everything looks good, is this a normal thing ? Or is this simptoms of something being worn out or miss-adjusted. The car only has 55,000 miles - I wouldn't think there could be to much wore out already..
Thanks for any input.
B
Bill C
When I purchased my 85 I had the EXACT same problems and concerns. I almost wrecked it on a road that had those truck wheel ruts in the road. The car will ride up on one or the other side of the ruts. I was in one of those barraced construction zones just wide enough for a truck. I almost S#!% my self as it was going for the barraced. The car gets weird when going over those things because of the wide tires. I had it aligned and it didn't help. VETTE Brakes has improved alignment settings that were suppose to help in those situations. It did just a little bit.
I also found out the HARD WAY that it attempts to do the side step in "wash board areas" during a turn! SCAREY!!! I inspected everything, had it aligned and then just learned to live with it and expect it. Coil overs are suppose to take care of that problem! :)
Drive the car carefully for a while and get use to all of the idiosyncrasys of the C4's
I have a C5 and it has it's own idiosyncrasys that I have to get use to!!
Bill C
Be VERY CAREFUL if you let someone else drive your car, It could be a very expensive learning expierence $$$$$$.
misterKTM
colton, oregon, usa
'93 Black 6 Speed
Thanks Bill,
It seems like it is just the way the car handles, it doesn't act like there is anything wrong - it's just real different than anything else i've owned/driven. I haven't had any real trouble with ruts per say (anymore than any other car anyway) but your description of the washboard side step is EXACTLY what I'm talking about.
B
Bill C
You will get ues to it and soon you will be hanging out the rear power sliding it through the turns!!!! :) :) You will learn VERY QUICKLY what it will and will not do and be able to predict it!
Have Fun and drive safely!
Bill C
