Steeroids Power Rack for C1 53-62
xplosive performance
Longwood, Fl
None right now, work on many
DON'T LET THIS GET BY YOU ORDER NOW!!!
SAVE THOUSANDS OVER THOSE MUSTNG II UNITS
NO WELDING
6-8 HOURS TO INSTALL
NO MORE WELDING CROSSMEMBERS AND MUSTANG II FRONT ENDS
EVERYTHING YOU NEED TO PUT RACK AND PINION STEERING ON THAT C1
Steeroids™ Offers Improved Steering Feel - Recirculating ball steering is vague and unresponsive, especially "on center". Control is greatly enhanced.
Kit is adjustable for bump steer.
Steeroids Offers Quicker Ratio - Steeroids™ power kits yield approximately 2.5 turns lock-to-lock (~2.9 for manual).
Steeroids Are Lighter Weight - Compared to the stock steering system.
Steeroids Offer Bolt On Installation - Absolutely no welding, cutting or drilling. Installs with basic hand tools in approximately 6 hours.
Steeroids Come As A Complete Kit -All necessary parts are included
Parts Included With Steeroids:
Rack and pinion - (paint finish)
Adapter brackets (powder coated gloss black)
Tie rod ends (Self cleaning & lubricating, teflon lined, adjustable for bump steer).
U-joint assembly (Alum Alloy)
Power steering hoses
Misc. fasteners (grade-8)
Steering Column
Power Steering Pump
Power Steering Pump Pulleys & Mounting Brackets
1953-1962 Corvette
  • Steeroids™ Offers Improved Steering Feel: Recirculating ball steering is vague and unresponsive, especially "on center". Control is greatly enhanced.
  • Steeroids™ Offers Quicker Ratio: Steeroids™ power kits yield approximately 2.5 turns lock-to-lock (~2.9 for manual).
  • Steeroids™ Effectively Eliminates Bump Steer: Only Steeroids™ offers adjustable tie rod ends to keep your car grounded and avoid darty behavior by keeping your alignment (bump steer) curves in check.
  • Steeroids™ Are Lighter Weight: Compared to the stock steering system.
  • Steeroids™ Offer Bolt-On Installation: Absolutely no welding, cutting or drilling. Installs with basic hand tools in approximately 6 hours.
  • New Power Steering Pump Provided: We provide everything you need to convert to power rack and pinion (or you can stay manual if you desire).
  • Steeroids Come As A Complete Kit: All necessary parts are included, including a new steering column.
  • Parts Included With Steeroids:
    • Rack and pinion
    • Adapter brackets (powder coated black)
    • Adjustable tie rod ends (Self cleaning & lubricating, Teflon lined).
    • U-joint assembly
    • Power steering hoses
    • Misc. fasteners (grade-8)
    • Power steering pump
    • Power steering pump pulleys & mounting brackets
    • New Ididit steering column (chrome or painted options available)
1953-1962 Corvette
Steeroids Power Rack & Pinion Conversion Kit for 53-62 Corvettes with Paintable Steering Column#
:boogieORDER THIS MONTH AND GET FREE SHIPPING IN THE LOWER US:boogie
WE HAVE INSTALLED MANY OF THESE UNITS AND THEY ARE BEAUTIFUL PIECES AND WORK GREAT.
