still a problem brakes 1973
johnrem46
new jersey
1974 Bright yellow t top
After bleeding the master cly and back brakes went to the front and replaced the calibers bleed the front and when i steped on the pedal it was hard. Started the car and no more pedal it went to the floor.. Should I change the rear calibers ? could they be sucking air I do not see any leaks? The front caliber were really bad..
I am using a one man bleeding kit and it sucks the fluid out. I always see some air bubbles can the kit be suckiing air through the pistions on the calibers ?
Yeah. . .one man bleeders always have air bubles in the hose. . .because it sucks air arround the threads on the bleader, or form the hose to bleeder connection.
I don't have power breaks in my car. . .so I don't know if running the car affect pedal feel. . . but I think not. Someone else would have to correct me.
Does your car have power breaks?
I have power brakes, I will keep on bleeding the system. Would the power booster have any effect on the pedal.
I may just get
I may just get a friend to help and bleed the brakes the old fashion way, thanks for all the help on this.
one more thing.
when you were bleading the breaks with the one man pump. . .did you have the master cylinder open (e.g. the lid off)?
When you bleed breaks the old fashioned way. . .you put the cover on and seal it. However when you use the pump. . .it's often best to leave the cover off.
-JR
