93Rubie
Ok, after looking around for the threads on thermostats and reading the 160 vs 180 thread. I have not been able to determine the stock LT1 Thermostat rating...is it 195 or 180. I found what I think is a credible source and it says 180. Verification anyone???
PLEASE READ AND CONSIDURE THE FOLLOWING CAREFULLY:
My question is, if my Vette has a 180 t-stat and normally running down the road it hovers between 196-203, in town the temp goes up slowly until the fan(s) kick on at 228. With that established, how in the world would a 160 t-stat help engine temps. The t-stat determines minimum operating tempurature. With the stock stat mine is a good 15 degress above that rolling down the road with good airflow over the radiator. To me it seems the stock cooling system is only capable of cooling to 195ish rolling down the road, I could believe seeing cooler if the system capacity for exposing coolant to air (aka 2 row rad.) was in place.
It only runs cooler in trafic with the 160 or stock t-stats with a CHIP, Switch to get more air over the radiator. I'm willing to bet that the guys running 160 t-stats that say, my temps are now 10-20 degrees cooler over stock dont run them long enough to get all the coolant up to temp. Remember that the LT1 has a two way t-stat, and that if your minimum operating temp is 160 it will take longer to get enough heat built up in all the coolant to see higher temps in the normal 195-203 range.
To sum it up, any cooling system is designed to get rid of so many BTU's exeed that and the engine will overheat. Thus, system design determines max. operating temp ROLLING DOWN THE ROAD with sufficent airflow.
If the system only can cool to 195 rolling down the road and the stock t-stat is 180, what is the advantage in having a 160, besides the fact that it will take MUCH LONGER to reach 195 rolling down the road.
ANY reading for my Corvette where taken from the digital dash readout. I have used a laser thermometer to measure hose temps highest I got near water pump with cooling fans just kicked on was about 215. Kind of hard to measure head temps as exhaust and other stuff is in the way and contribute extra heat.
ANYONE MAKE ANY SENSE OF THIS OR AM I NOT CLEAR ENOUGH or OFF MY ROCKER ONE OR THE OTHER.
