02VetteCoupe
I have owned my 2002 for almost a year now, and besides new tires and regular maintenance on her, the only thing I've had to do was get the new Steering Column harness (it's a manual and the lock was removed with the recall in 04, I ended up with that problem). Recently I've been hearing like a vibration noise coming from the rear of the car. It's related to wheel speed, not RPM. I can hear it on the highway or whenever I turn the radio down. Never heard the noise before recently. Earlier today my active handling showed up while I was driving perfectly straight down the highway. It felt a little wavy while it was activated, it was weird. I pulled over and checked around the rear right wheel (where it seems to be coming from), and without the car moving, it's hard to figure anything out... Do you guys think it may have something to do with the Transaxle? It sounds like a tire with a nail in it hitting the road as it spins (but I've had that problem with it and replaced it, this sound is more subtle, and faster). I can't think of anything else besides something wheel or gear related. The only faults I have are historic body codes 0361, 2283, 2284, 2285, 2265 and code U1160 which probably means I need to replace my battery soon (which may also explain the remove key, wait 10 sec that I got again the other day, scary shit!). But other than those, I have no other readings, tire pressures are good. Could this be a transaxle issue? Or something smaller? Thanks for any help.
BTW the noise sounds kind of like road noise but suddenly in the car, louder on the passenger side toward the back (I've thought of weather stripping issues, but my car is very clean and well maintained and this is sudden)
