Achilles
Somehow unknowingly, I stripped the threads for the lower bolt hole for the EGR heat pipe mount on the intake. I noticed a slight exhaust leak yesterday and when I put a wrench to the mounting bolts, the lower bolt just turned freely. I'm assuming I can just drill the hole out in the alluminum intake to the next size and re-tap it with no problem. It looks like a larger bolt head will clear the pipe just fine. But I thought I better put a thread out there just in case there is something I'm not aware of, or an alternate fix. What do you think?
