K
Kicnrocks
I have a 1968 427/435 4 speed that has become stuck in first gear, stick is mobile, I read that on some of the transmissions a pin falls out that prevents the gears from being shifted. I have had a look and nothing from the linkage appears to be the issue. MY question is do I have to remove the linkage and cover housing to locate the "pin" ?., and if so can it be easily observed once open? Or is their another way to solve this problem?
Clutch is working well.
