Help! stuck window
jay50n
san angelo, Texas
2004 C5. black
my passenger side window on my 2004 coupe has stuck down. i cannot get it back up.............any ideas?????
no i dont garage it or have a car port so it is taking on water............i pulled the panel to see if i could see anything but no. all i hear is a clicking noise as the relay turns over but nothing on the window.
for now i want a quick fix to get it up. i tried pulling on it as my wife hits the button but it is stuck solid........help????
ty
HI there,
You can attempt to remove the door panel and maybe tap the motor with a block of wood while someone holds the switch up.
Sometimes that will work.
Otherwise, it sounds like a regulator/motor assembly.
Allthebest, c4c5
thanks for the replies. i fixed it. took the motor to pieces and cleaned the brushes. works just fine.
