Subwoofer Box
  • Thread starter Thread starter Crew Dawg657
C
Crew Dawg657
Anybody know where I can get a sub box to fit in the rear compartment?
Just had a system installed in my vert. All new speakers, head unit, cd changer & amp from my wrecked Benz and a new Sub. Will post pictures 7/22 or 23.
Sound advice can build you one that will flush mount in the back. I have 1 12 Kicker soloberic Everything else is Boston acoustics. Sounds 100 times better than stock. I also have a 1000 watt amp. I did keep the stock head unit. since the cars sound system is hidden. O also JBL or JL audio has a custom box for the C5. Its only for a 10 but thats plenty.
Pics of new system
Here is the set up I just had put in. I had the Eclipse Head Unit, CD Changer and Amp from my previous vehicle. New Boston Accustics up front, Memphis Audio on the rear deck, and Crossfire Sub in the rear. Sound is incredible compared to stock Bose.
ToTall: I have that same exact head unit!
I'm running an amp w/ the stock Bose in the front (some work had to be done to get them to work), and a JL Audio sub in the large cubby hole in the back. Sounds 1000 times better than stock.
AZ Mike,
Have you considered the commander unit add on for the eclipse?
I'd been toying with the idea since I got the unit but the Mercedes was just too noisy with the top down. The vette might be worth trying it.
No - I'm pretty happy with mine the way it is. I really don't see the need for voice control since the stereo is right there by the shifter.
I usually turn the volume down when I'm dirving in situations that require both hands on the wheel anyway (like navigating my favorite shortcut/racetrack between Maricopa and GilaBend). I like hearing all those ponies being made at those speeds.:D
