EOLIVER
- Joined
- Dec 14, 2003
- Messages
- 116
- Location
- SAN DIEGO, CA
- Corvette
- 1989 DARK BLU METALIC SIX SPEED CONV
I have 1 1987 4spd automatic that my son drives. A few days ago the engine began to die while he was driving (without any prior warning or sysmptoms like rough idle) and all the lights (dash, exterior etc) would flash out of control. Upon trying to restart, sometimes it is as if the entire eletrical system is completely dead (no starter click, lights, nothing). Additionally, upon trying to restart it might take several turns of the ignition key to start, or it would run for a few seconds and then die (sometimes I actually had to pump the accelrator pedal for it to start). For the past two days I have been checking all the grounding points and straps, and I have found the positive battery cable ground point to be rusted so I cleaned it up. Secondly the Positive battery terminal block was pretty rusty so I have ordered another one. I plan on reading the for codes once I install the new battery block. The main thing that concerns me is that the dash cluster goes totally wacky (all the lights flash on and off and continue to flash upon engine start) and results in a no power situation is this a ECM problem?
