supercharger
liverpool england
white 69 spec. convertor lockup on manual switch
thinking of fiting a supercharger not shore which one to use. aparently certain ones cant be used whith hei distributor.can anyone point me in the right direction here.not many stingrays in liverpool.;help
You looking for an underhood or one that sticks out the bonnet like a 6/71?
Why do you want to supercharge the vehicle....?
Since you are talking about HEI clearance you must be considering cutting your hood. Edelbrock has a new blower that may clear your distributor. Contact them for more info. Also the Magnacharger might fit your needs.
If you want to keep it under the hood take a look into Procharger's carburator systems.
Tom
i think supercharging is the simplest way for more horsepower.eng currently around 300 hp 4 bolt mains pro damper edelbrock cam and gears big valve heads stainles 1.5 headers twin straight through exhaust whith balance pipe under g/box 9.5.1 com. quadrajet Ho. dont mind cuting bonnnet but want to retain hei dist. thanks. howard
