Shelly,
81 was the first year they used the Mono Spring, I won't say ALL automatics got it, because there were a few that got through production with the old 9 leaf spring, not many but a few.
On the other hand ALL FE suspensions came out with the 7 leaf spring.
You can still check for the rear sway bar and size of the front stablizer bar. Some folks changed out their rear spring for the Mono Springs for a softer.. err ah smoother ride
Statistics and playing with the numbers
FE7 (Gymkhana) = 7,803 (Production)
ZN1 (Trailer Pkg, includes the FE7 opt.) = 916 (Production)
The ZN package included the FE option,
If you ADD the ZN1 to the Total FE7 would mean 8,719 built
or
If you Subtract the ZN1 from the FE it would mean 6,887 built
(I'm not sure which way this would work)
So if your car has the (Factory) Trailer Package Option, then it would have the FE Option and most likely if you have the trailer option it also would have the FS1 (HD Shocks).. so what are the odds of your 1981 (of 40,606 built for production year 1981) having the FE suspension????
Numbers / Statistics drive me :W :crazy
Good Luck Shelly Check your Door Tags too for tire size and loads ..
Bud
