Synthetic Motor Oil Change
Greekman
Parker, Colorado
'67 327/350-'73 LS4-'76 L48-'79 L82
I am wanting to change my engine oil to Mobil 1 Synthetic. What is the proper procedure for doing this right? My engine has 48k miles on it.
Should I use a Engine Cleaner or Wash to add to the cranckcase prior to draining the old oil out?
Will I experience leaky gaskets or seals?
I dont' plan on puting more than 2k miles per year on my Corvette so I thought with the Mobil 1 Synthetic oil I could change the motor oil just once a year.
What is everyone's thoughts on this procedure.
Don't really want the Mobil 1 vs. Amsoil debate as I have already been there.
Thanks in advance for everyone's help.
danl72
Chatsworth, CA
2008 C6 Coupe
Mobil 1 come in the Vette when you buy it new. I use it and always have. Just change the oil like you normally would.
Greekman
Parker, Colorado
Synthetic Motor Oil Change over
I don't believe it did in 1979. The Mobil 1 synthetic motor oil use from the factory has been recently in the 1990s if I am not mistaken.
I have heard some say use a motor oil cleaner to remove any sludge from the engine before installing the new thinner and lighter synthetic type.
Thanks for your reply.
Tomrw
Columbia, MD
2000 Black Conv. Bassani Exhaust.
My understanding is that then going to Mobil 1 after using fossil based oil you can expect to have leaking from the engine seals and gaskets.
Tom
Greekman
Parker, Colorado
Mobil 1 change over......
Tom, thanks for your reply and thoughts on the oil change.
I did already go ahead and changed over to Mobil 1 synthetic motor oil and used a motor cleaner before changing. So far no leaks or problems. I was having a slight heating problem where the water temp gage was running aound 210-220 with a new 195 thermostat in. Since the oil change engine seems to run a bit cooler and hasn't passed 195 on the water temp.
I did change over to synthetic and Mobil 1 on my 4x4 truck a couple of years ago and it had 37k miles on it. No problems there either, so maybe I'll be okay. I hope so.
Thanks again,
