t.b bye pass free mod?
sxyvet
Dandenong,victoria-Australia
1991 ZO7 coupe, 6 speed,red on red w/most options!
hi there guys,
i saw some one mention a t.b bye pass mod which you can do your self!
can you do this mod on l98 1991 engine at all?
i tried doing a search, no luck!
any one know if this is possible annd how to go about it?
thanks guys.
from glen
sxyvet- australia
I had the same question about the LT5 engine ? :confused
cant answer your question directly, but I can say that the TB Bypass mod is not noticable. If anything, it gives you a chance to get your hands IN your engine bay for the first time without messing up anything else.
(well, you can kill the opti spark if you get it wet.. so ignore what I just said) haha
Honestly, for the small gain in HP, it is not really a needed mod.
Rain
It will not give a noticable power gain, but the coolant not being in the TB allows the plenum and TB to remain COOLER, which helps prevent heat soak of the intake which kills the L98's power.
All you need to do is remove the coolant hoses from either side of the throttle body and mate them with a small piece of pipe and 2 clamps. Or you can do what I did and use a longer piece of 5/8" hose to reroute it without clamps and pipes.
yeah i did like Vader, and the main reason why was the little C shaped hose from the manifold up to the T/B was dried out and leaking. so i lost it, and ran a new hose from the heater value line to the mainifold. so no line going to the T/B now. only cost new heater hose.
