T/T Steering Column
72LT-ONE
Rancho Cordova
1972 Sunflower LT-1
Quick question...Would a T/T steering column allow me to locate the steering wheel closer to the dash than a standard column? Right now the bottom of my (standard) steering wheel is 21" from vacuum override knob, which I used as a reference. Can someone who has a T/T set up, and is willing to dig up a tape measure, please take a few minutes out of there schedule and make this measurement for me?
Thanks,
Michael
My tele goes from roughly 19" to 21". I measured from the vacuum knob right up the steering column to top of the horn on the steering wheel. So basically I have 2" of tele movement. Hope it helps! :beer
My vac override knob is missing so I don't have a reference point but I did measure the travel and it's the same two inches as tonyk has on his.
T/T
So basically what you are saying is that the closest you can get it is 19" to the front of the horn button. This is the info that I needed, however it's not the answer that I wanted to here. I thought that maybe GM would have split the difference and made it adjustable between 18" and 20". 19" is the distance of the standard column at the points you measured. I really appreciate the help. Humm....I wonder what it would take to shorted it to say 17"?????
Thanks,
Michael
I would prefer mine shorter also. I think it would take major surgery to make it shorter and probably more work then it would be worth.. Just bend your elbows a little more.
I am not completely comfortable with mine even with it retracted all the way, but then its not a Cadi either.
