7
714Speed
The tach cable on my 71 is practically new, but was installed more than a year ago, but practically less than 100 miles since installation. I did not install it, but here's the condition I found it in.
It started chirping and squeeling, so I unhooked it at the distributor. It had just a dab of grease on the end, and I shot a little graphite down the tube. The horrible sounds stopped for about 30 miles and then began again.
When you lubricate with grease, can you take the cable out of it's casing? Obviously I need to do more greasing or graphiting, just don't know how to go about it. What would your plan of attack be?
