To go from 1 tail light and a reverse light, to 4 tail lights and no reverse light. Be sure that your state dosent require reverse lights before going any further.
Here are the only tools I used.....
You will need to get the parts you need to do the job. My car came with the "California" style bubble tail light lens when i bought it.
So all I needed was the pigtail for my year car.
(I got mine at Rik's Corvettes parts in Florida.They came as a Christmas gift to me but run less than $10 each I believe...
http://www.riksvet.com/
But if you need the lens to finish the job you can go to here and get the entire kit to do the job including the connectors and all.
http://www.madvet.com/shop?frame=4.249.462
I had to use 4 jumpers to connect the 2 wires......
If you have small hands and arms you wont have much trouble in the tight spots, but if not, just be patient.
Disconnect the battery.
Drop the spare tire holder out of the way.
Remove the lens cover and light bulb.Now you can reach up and unplug the current holder from the housing. I wrapped mine with electrical tape and left it there incase it needs to go back to factory specs in the future.
Now plug the new connector into the socket. It works just like the light bulb unscrews, a half twist and it drops right out or in.
Now you need to jump the 2 wires with the blue connectors. This is where small hands will come in handy!
When that is done it is time to put the light bulbs in, but first you need to file ( or dremmel if your kids didnt lose itad ) the little nub down on one side of the bulb so it will fit the old style socket. The 2 nubs are in a diffrent location than the reverse light so one has to go or it wont twist into place.
The one that needs to go is the one furthest from the end of the light connect points.
The arrow points to the one you need to remove.
Plug the light into place and put the lens back on.....reconnect the battery and you should be looking like this.....
I left out one bulb so you can see what the diffrence looks like. Again, the way I have it stored for winter its hard to get a good photo but i think this is a good example of it.
This is a project I have put off , thinking I needed to replace the entire light housing and I was wrong. This was a fraction of what I expected to pay and it took alot less time than I thought as well.
I hope this thread helps you to decide wether or not to do it, and if so, i hope the tips I provided here help also.
Im really happy with the way It looks with all 4 lights lit!
Good luck, Chas
Good luck, Chas
