Tail light removal
  • Thread starter Thread starter Corvette Craig
C
Corvette Craig
I bought a new LT Wing for the rear end yesterday.
They tell me it needs to be installed through the tail lights.
Any info on removal would be VERY handy.
Craig,
Remove the two torx head screws screws from the light lense and them reach up from behind and give it a push. The whole assembly comes straight out. You can remove the bulb holder with a slight 1/4 turn twist. You can do this before you remove the screws if you like, otherwise you will have to hold the assembly from turning while you remove the bulb.
