norvalwilhelm
I am forever pulling my seats in and out. To make life alot easier to do this job I install carb studs in the floor. The bolts holding the seats are 5/16 coarse. A carb stud is 5/16 coarse on one end and fine on the other. Studs 1 3/4 long can be inserted in the floor, I use green loctite and install 4 studs.
Now the seat is simple to install. Just drop it over the studs, easy to align and install 4 nuts and washers.
Alot quicker then trying to line up the holes and start the bolts.
Anyway for racing the passenger seat can be remove in about 2 minutes. Use a 1/2 socket, a 6 inch extension and ratchet and the nut is quickly removed, not hard to get at and lift out the seat.
Do it a few times and it becomes easy.
Years ago when I was heavy in street racing my passengers seat spend most of it's life in a garage.
5/16 th carb studs 1 3/4 long work great.
