Tank sticker
I could see mine by looking up between the front of the tank and the storage well. The sticker was dangling over the edge of the tank. With a light you could see the bottom of the sticker and I could even see the writing on it.
Pulling the tank isn't that hard. I had the local mechanics give me a hand and I used their hoist to drop mine. You don't need a hoist, but it does make it easier. The spare tyre storage area must be taken off along with the tank cross member. Some guys disconnect the fuel lines, but if you use a hoist, you will not need to as they move enough to get your head and arms up to slowly remove the sticker with a razor blade. Really easy and only took about an hour and a half.
Hey, it may not be there, but if it is get it off before it is cactus. My sticker had to come off as my car is a St Louis car and there are no build sheets available from the NCM.
Cheers
Tony
