Targa top interchange ?
acme-corvette
istanbul Turkey
1996 coupe LT1 metalic purple
Hi everybody,
This is my first thread here.
I have 1996 LT1 coupe / metallic purple. I have restored the car from chasis to the top. Now the last part is glass and locks.
The original top was missing and all I could found is first design (84-86) top. I have the correct 96 mountings on the frame. Is there a chance to convert early tops to fit late design mounting tabs?
Should I look for 84-86 design mounting tabs? or work on the top connection parts?
Thanks at the beginning.
Yes you can change to the early style , but why?
If you have restored it put the correct top on.
tcxd40
I wouldnt go with Thompson if I were you.:bash I did and they are vastly inferior to OEM. They poorly refurbish the frames they receive in exchange. Paint came off a corner of mine the DAY I put it on! They added a sticker to the inside above the mirror with their name that removed paint when I removed it.
They use a cheapo weatherstrip at the edge that pulls off (my original oem one had metal edge) -where you put the top in the rear brackets.
The rear inch of the top doesnt have the OEM blackout tint so you see the metal bracket from the outside. :puke
All in all a very poor substitute for OEM!
Wish I had just spend the extra $ and bought OEM :beer
Thanks for the replies,
I live in overseas and its hard to find parts here, also shipping kills :(
My Oem one is missing. All I could find is the early style. But I ll check e bay to catch an OEM one.
