Tell me about batteries.
Norcross, Georgia, United Stat
2017 Arctic White Grand Sport
Last battery I bought was a top mount and the only two things you were looking at were cold cranking amps and warranty. And as I recall, the higher cranking amps were usually longer waranteed batteries.
I know I need a side mounted battery this time. Is there any thing else I need to be aware of. What cranking amps should I be looking at? Are any brands better than others?
Thanks.
I have no real preference as to manufacturers or brands (although I do use a red top Optima battery myself); they're always coming up with something new and improved. ;shrug
I guess there was a problem with Optimas for a brief period a few months ago. I remember a couple of threads on that subject, but I think the whole issue was a fluke; a batch got screwed up somehow or the other. Haven't heard anything bad lately regarding the Optima red top.
I remember that thread.... about Optima lifespans....
Wow, the '77 used sidemounts, huh? My 75 uses top - and I will only ever buy Optimas in the future unless price is an object.
These spiral cell, almost gell cell, type batteries, of which the Optima is one of the earliest and most widely known offer a lot of advantages. They never leak and can even be mounted upside down. Even the non-deep cycle types (the red tops) tolerate a much greater discharge (repeatedly) than a standard liquid multiplate lead acid variety and are really halfway between a regular and deep cycle version of those. Another great advantage (the other one that made these an early favorite with the 4 wheeler (not "ess-yoo-vee", but REAL "he-manly" FOUR WHEELERS :D ) crowd is they are much more resistant to physical shock.
One drawback is their lifespan is typically less (as is their peak cranking amp performance - in general) and when you approach the end of that span, they tend to drop out quickly. This can alarm an infrequent enthusiast, but isn't really a problem if you just change them a year or so before the stated lifespan or as soon as you notice even a relatively small drop in voltage before startup from what has been normal in your car (something on the order of 0.3V is cause for notice.)
A question I've always had is how heat resistant are they compared to a regular lead acid battery? If it hasn't leaked away, the liquid acid solution in a regular battery sloshing around between the plates pretty freely would seem to make it reasonably tolerant of heat, and I don't know if the same is true of the Optima types. This is not a big concern in C3's since the battery is where GOD intended - away from the engine heat and towards the rear where the weight is better put. (Some might note this auto design god had mysterious reasons indeed for not putting it behind the passenger, but that's another topic.)
The car currently has a side mount in it. I assumed they came with side mount because of the door. I don't know why the prior owner would have changed from top to side. But you never know with prior owners. :L
75 should be right for the 77. Make sure the case size is the same as yours. Then it will fit. The Interstate book says 65-75 will be a match.
You know I really have no idea if mine started as top mount....
Since I've had it three years, I may have even changed it myself if it didn't come that way....I know I wanted to use the battery disconnect green knob thingy so it is possible I changed it to top mounts myself....or if one of the 57 previous owners did (they changed everything else!)
All 1975's were originally equipped with side mount terminal batteries. When I got my '75 it still had the original battery in it (3 years old).
Mike
getting back on the original subject, LMAO!! i think one of the biggest features of the new "gel-cell" batteries is that they do not produce any fumes as do conventional batteries. i feel that is particularly importatant with the battery in storage behind the seats on the interior of the vehicle. BTX the orginal configuration for 78 is definitely side posted batteries.
