401KVet
I am replacing the center plastic bezel, the one with the water temp, oil, clock etc. gauges. Doing so I replaced all of the bulbs with new long life bulbs. Testing things before putting it all back together and I have two problems. None of the lights are coming on, and the water temp gauge kinda seems to be stuck. After idling for 15 minutes or so it has only come up about 1/8" off the left side. I'm quite certain the engine was much hotter. The fuses are good. I've checked things over and all seems to be right. All was working before I went in to it. Does anyone have any suggestions??
