I've got a similar problem but alot my wiring has been chopped out. I've located the single green wire for the sensor on the drivers side bank but I can't locate the wiring or the circuit for the auxilary fan. My assembly manual shows that there may be two senors, one on the drivers side bank for the gage and one on the right (passengers) side for the auxilary fan. (If I'm reading the drawings correctly). My problem is that the original motor was an L48 (blown up) and an auxillary fan was not an option on the L48 model. The motor I installed is a 1976 L82 and the second senor hole is plugged. I'm assuming that the wire harness was the same for the 1979 L82 and the L48. Does anybody know what wire(s) or colour(s) goes to the fan. From what I've read this set up seemed to change in the 1980 and up to a single dual sensor. I purchased a new Auxilary fan extension harness. so I can go either way I suppose. Can I ask a little guidance from any 1979, 1980, 1981 owners?
Thanks,
Steve
