well, BABY is now showing another problem again.
About a week ago the temp gauge starting to not register above approx 110 degrees. Even on a very hot day and after driving for a good amount of time the temp gauge won't go above approx 110.
What are the chances this is only the sender unit going bad?
If I had an actually cooling system problem the car would be running HOT instead of cold right??!!
Is it possible to check the sender unit and is it relatively easy?. how hard is it to replace if I need to and can I get one locally like at Autozone or Pepboys or do I need to order a specific one from LICS.
Barry
PS: I knew 2 or 3 weeks without any problems was pushing my luck and something was due to crop up soon! :L
Barry
