JL66REDCPE
How do you test the Ph level in your radiator.
I don't know if you will get the same accuracy, but if you have some test strips around for testing the swimming pool PH I would think they should work. I never thought about it before. I would think PH is PH regardless of the make up of the liquid.JL66REDCPE said:How do you test the Ph level in your radiator.
Very close.DRTH VTR said:If I remember right, pH is the negative inverse of the hydrogen ion concentration.
Just checking the PH does not help much. The antifreeze looses its lubrication & corrosion properties over time and then starts to attack the cast iron & aluminum also the waterpump will not be lubricated.JL66REDCPE said:A high acid condition will promote rust.
Actually you do not need 50-50 mix unless you live where it gets -35 deg. below. Antifreeze is a poor heat conductor water is much better. Using a mix to -20 to 25 below is more than enough in most cases. If you park your baby in a unheated garage like i do it will never freeze inside.JohnZ said:As pointed out above, the anti-corrosion additive package in anti-freeze deteriorates as it does its job, and it should be replaced every two or three years; OEM's recommend using only distilled or de-ionized water for the 50-50 mix. Water pumps haven't needed lubrication for many years - they use sealed bearings.
