Bernie came over after work this evening and helped me take off the exhaust manifolds. Well, a slight correction, I helped HIM take them off.
Man, those things are a PIA, I'm VERY grateful for his help. I'm sure I would have managed in time, but he had them both off in an hour or less and I can see it would have taken me at least an entire day. Those french locks alone would have had me throwing things around the garage. the person who came up with THAT idea should be shot!
Anyway, after we finished getting them off the car we ran them down to his workplace where there is a glass bead blasting machine and we got both manifolds and the heat riser all cleaned up and looking nice and new. Man, they look AWESOME!!
Now I just need to get the paint for them. Will either go for the Eastwood's "Factory Gray" paint JohnZ mentioned or another product by Virginia Vette's that was also recommended to me so they continue to look this good and not rust.
I do have a lot of cleaning to do on all the bolts, studs, french locks, and all the shielding brackets and shielding pieces that go along with the exhaust manifolds.
now I just have to get the intake lightly glass blasted and deal with the valve covers. I think I'll probably NOT glass bead blast the covers but rather follow another recommendation which is take them to a local automatic transmission repair place and see if they will take the covers and put them in their big parts washer machine they use for the aluminum transmission cases. hopefully that will clean them good enough so I don't have to blast them also.
here is a pic of one of the freshly glass bead blasts manifolds and the heat riser
