bossvette
Gone but not forgotten
I'm thinking of selling the 76 since I have not driven it in two years but want to keep the TKO for the 68 and with the price of gas have decided to go with a 305 TPI/700r4 set-up. Why a 305 you ask the L-48 that was in 1976 was rated at 180 HP while the optional l-82 was rated at 210 HP and 255 torque the 305 which I'm putting in is from a Firebird GTA which was rated at 230 HP and 300 torque so it will be an improvement in all areas
the 383 ready to pull out this engine was built in 1989 and has many many miles on it with Mobil1
the engine bay got a quick pressure wash and a little spray paint
the hardest part was swapping out the pedals
the 305 has a new home it was rebuilt at some point and the trans has a fresh rebuild so it should be good for quite some time
all these wires need to go in somewhere
I started by laying them out to be sure everything would reach
next the injectors and fuel rail go on
then the runners and plenum are installed
I will make a bracket to hold the relays and main power fuse
