The 832nd Question On Headlight Doors
Redcoupe864+3
Belchertown, MA
'86 Red Coupe, 4+3, Z51, Sport Seats, Old Pilot
Did a search and haven't found my specific problem, though I have an idea or two on what to expect. So here y'are: right-side headlight door on my '86 had occasionally been reluctant to rotate into position, but would always come around when I retried it. Now, it's decided it doesn't wanna rotate no matter what. Open the hood, try the lights on-off real quick (the left is fine), and see that the door starts to rotate and stops after a few milimeters, as though something was blocking it. Can't find anything in the way, and my garage man said today they couldn't even manually get the light into position. Now, I myself have not tried to bring the light up manually, but I thought that the "hand crank" backup for the lights was a pretty foolproof thing. Oh, and my man says we're probably looking at stripped gears, which I suppose wouldn't be too surprising. Thoughts out there? Thanks as always!
Check your MAMW catalog for the parts you need for your year.
My 89 uses plastic cylinders as clutch pieces ($5.00 each side).
Earlier years used a pair of gears for each side ($50.00 / set).
Either type seems fairly easy to fix.
I have my parts but I'm waiting for a totral failure to actually fix them.
So far they open on several tries.
HTH
I had one that wouldn't open, and before I went to the trouble of tearing it apart, I lubericated everything and it works now fine. I know there is some information on repairing the head lights by replacing the gears and bushing, in fact someone found the nylon bushing at home depot. I am sure that someone here proably has the repair site marked. good luck, they say it only a couple hours of work during the winter months. Save the :w
Guys, thanks for the suggestions. I'm getting the car back tomorrow and will try lubing stuff first. Replacing the gears seems to be the most logical next step. Appreciate your help!
