R
RVN
I bought my first corvette last July, a 2002 black ZO6 w/66K. It's my daily driver and I've had the jingly sound all the time after it's hot. From everything I've read I have all the symptoms indicative of the exhaust crossover turbulence problem. However, I'm worried that it's something worse in the engine or drivetrain rattling loose or spinning. And now, all of a sudden, for some strange reason the "jingly" noise seems to have disappeared on it's own over the last week.
The car has undersize tires on it for some reason, P255/40ZR17 and P285/35ZR18. I was wondering if this miniscule decrease in overall height would have anything to do with the "service traction", "service ABS" and "service active handling" warning lights.
My codes are: TCS1214, TCS1293 and LDCM2284.
The warranty campaigns that have been performed are:
08/11/2005 243093 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 45007 miles
07/21/2003 197173 # N2829 - RELAY - ENGINE WIRING - REPLACE 20379 miles
03/03/2003 188839 # N0110 - BATTERY - ONE - REPLACE 15591 miles
01/13/2003 186525 # R4060 - FUEL TANK FILLER DOOR LOCK ACTUATOR REPLACEMENT 15001 miles
07/08/2002 246432 # E7200 - IGNITION LOCK CYLINDER REPLACEMENT 7899 miles
07/08/2002 246432 # N2320 - IGNITION AND START SWITCH REPLACEMENT 7899 miles
04/03/2002 274917 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 1433 miles
Thank you very much for any forthcoming advice.
