Just ordered almost all the rest of the parts I need for my own "winter project." The upgrades look something like this:
1. Accel SuperRam intake, runners, base, mildly ported and gasket-matched by Les Schmader of Lesport.
2. Accel 74219 roller cam
3. Comp Cams retro-refit hydraulic lifters & associated conversion hardware
4. GM Performance 1.6 full roller rockers
5. Hi-flow water pump (forget the brand - Flowkool?)
6. Accel hi-output fuel pump
7. Pro Topline aluminum heads (200cc intake, 64cc chamber, 2.02/1.6 valve openings), gasket-matched and bowl-blended by Les Schmader
8. Stainless steel one-piece valves
9. Rollmaster Billet Steel timing set (9 position crank gear, full roller/pin chain, torrington thrust bearing)
10. ARP fasteners (12-point head bolts, 6-point everything else)
11. Dave Koldos 52mm throttle body
12. Victor steel core head gaskets
13. When I scrape up the $$, Ken's performance distributor and rev limiter kit
14. A rework of Jeff's custom chip
15. Rebuild of stock fuel injectors
16. 3.45 rear gears (maybe...)
Think that's it...
Haven't gotten pushrods yet; will need to measure the final length after assembly (thanks for those who informed me of that).
[RICHR]
Think that's it...
[RICHR]
