Stallion
Okay, tell me if you agree...
I took off the bell housing, unbolted the pressure plate and clutch disc. Well, it turns out that a clutch disc spring is off and floating at the bottom of the assembly.
So I'm guess this is the culprit to my clutch problem?
Woohoo!! So glad I found it. I had this bad feeling in my stomach that I would get it all apart and everything would be fine. But, this isn't fine. Sheesh!!
Stallion
BTW, if you don't know about my clutch problem, it's all explained here: http://corvetteactioncenter.com/forums/showthread.php?t=44669
Stallion
