S
swmdal
I'm thinking of buying a black 1990 Coupe with 83k miles from a friend. It drives well but has some issues. Before I sink a lot of money into repairs (I"m not a mechanic, this will be done at a shop), do any of these sound like deal-killers? Any thoughts will be appreciated.
MUST BE FIXED:
-Airbag light/seatbelt light both stay illuminated
-Tachometer is registering several thousand RPM too high
-When the car is stopped and I turn on the headlights, the right headlight doesn't open fully or sags back down, and the emergency manual backup knob doesn't work. However, if the car is moving at about 30 MPH or more and I turn on the headlights, the right headlight opens normally and stays open.
-"sys" light to the left of the fuel gauge keeps blinking
-Strong buildup of fuel vapor is released when the fuel filler cap is opened if the engine has been running hot (extended slow speeds on a warm day.) Vapor can be smelled inside the car if windows are opened while driving.
NICE TO HAVE FIXED:
-Cruise control inop
-Bose CD player doesn’t work
-Left front channel audio only makes popping noises—previous owner disconnected the speaker for me to stop it (maybe cheaper just to put in a new aftermarket system than to repair?)
-Passenger interior door pull is separated at the top (vertical part of door pull)
There are several other minor items like weatherstripping and shuddering brakes. The drivetrain feels strong, as does the steering and adjustable suspension.
Thanks!
MUST BE FIXED:
NICE TO HAVE FIXED:
Thanks!
