G Winter
I think I finally figured out why my 90 idles to fast most of the time and now and then searches.
I noticed the other day that coming to a stop sign it hardly dropped below 1600 rpm. I burped it and it settled down to it's near normal (for this car) idle speed.
Back in the garage I played with the throttle shaft and I do have some noticeable play. I took the air tube off and put my finger against the shaft on the inside and could feel it there also. I had always checked it with the engine running, apparently you can't move the shaft against the pull of the engine vacuum when it is running.
Is this my problem? How much will this effect idle speed ?
Glenn
Glenn
