Timing 90-L98 engine?
  • Thread starter Thread starter DHOUGHTON
D
DHOUGHTON
Ok I took out the Hypertech chip and re-attached battery. HEI is disconnected also. I am ready to go. Whats the best setting? +3 or 0 or what. Timing light hooked up and I am ready to go. Engine up to normal temp. Lets go Zooooooooooom.
Marathoner
The L98 base timing is set to 6* BTDC from the factory. If you are looking for maximum performance though that will require use of an ECM scanner to monitor and knock counts you get with added timing. I would set it to 6* BTDC for now and see how she goes. :D
Thanks for the response. No rocket science here but a little brain surgery might work.
Happy new year,
MARATHONER
Where abouts is 6* BTDC
Front of car
----v--V--v--v--|
O
My timing guide has marks that look like this, the red mark is the mark on the damper.
Does this indicate 6* BTDC, the mark is nowhere near the guide.
Mart
