1
1978L48jafo
As you can see from my signature list my L48 engine has had a rebuild and is no longer the 8.5:1 smogger. I have kept the factory timing setting since the rebuild and I am wondering if this is a mistake based upon some posts I was reading through.
My compression is 9.5:1 due to flattop pistons, steel shim gaskets, and machining done to the heads. I am also running a mild street cam (Performer Energizer) Performer intake with the stock Quadra jet. The distributor was overhauled with the proform performance kit and I choose the middle of the road centrifugal advance springs. Exhaust is chambered under the car system from Corvette America.
I believe the factory timing for a 78 L48 is about 6 BTDC. Is this ok for my current setup? Please understand the car runs excellent I just wondered if it could be better....
John
John
