B
bwarren
Ok, need some help here? I may rattle on for a bit, but please stick with me and go easy on me. 1995 LT1 100,000 miles. I recently replaced the oil pump, all crank bearings, valve guide seals, timing gear/chain set, and water pump. I have done some engine rebuilding in the past and felt confident completeing this work. I used a Haynes manual for reference. After getting everything back together, the engine seems to be only running on 4 cylinders. With a timing light, I verified current is passing through all plug wires. I verified plug wire locations 4 times. Removing injector connectors on at a time only seems to affect cylinders 1, 3, 5, and 7. 2, 4, 6, and 8 seem to be unaffected by disconnecting the injector when the engine is running. Plugs on 1, 3, 5, and 7 are clean. Plugs on 2, 4, 6, and 8 are black. Moved plugs from one side to another, no change. Thinking I must have messed up the timing when installing the chain, I tore everything back down. I opened the Opti so I could see where the rotor was when #1 was DTC and it was pointing to #1 on the distributor. I ohmed out the distributor so I could label the outside of the opti for firing order reference. I went through the entire fire order and valve and piston position seemed to match what the distributor indicated. With everything at TDC for #1, I noticed that the timing marks on the cam gear and the crank gear were both at the 12 o’clock position. The Haynes manual says for 92 and later models, the marks should be facing each other. The cam at 6’ o’clock and the crank at 12 o’clock. At this time if I line the marks up to match the manual, the rotor is firing #6. I do seem to remember when I removed the old gear set, that with the marks facing each other, #1 cylinder seemed to be transitioning between intake and exhaust. That’s how things are now. I compared the old timing gear set with the new and they are the same. Could the crank have been 180’ out of position when I installed the chain? How can I get #1 to be TDC and have the rotor pointing pin #1 on the distributor? Is the Haynes manual wrong? Could I have too much pre tension on the lifters for 2, 4, 6 and 8? Could a previous owner messed things up and rerouted plug wires to make things work?
Thanks for reading. Brian
