twamd80driver
On my 76 the door tag says 20lbs. in the front and 26lbs. in the back. Does that still work for todays modern tires?
Thanks!
Thanks!
twamd80driver said:I am running Goodyears now, and am curious what types of changes in performance you get when you add or subtract tire pressure?
Stallion said:Well I think the general rule of thumb is that the lower the tire pressure, the more tire on the ground, and the more traction. But there is happy medium between too little and too much.
jason r. nugent said:tire pressure it is marked on the tire you should use it as a guide line any where between 26 psi and 40 psi depending on the weather conditions and tire makers seek information from tire seller for best determination of psi or a local car dealership
No, unless you want to be another Ford Explorer flip over statistic. It looks like you've gotten some good numbers from people here. 30-34ish p.s.i. when cold.twamd80driver said:On my 76 the door tag says 20lbs. in the front and 26lbs. in the back. Does that still work for todays modern tires?
Thanks!
Stallion said:I thought those SUV flips came from overinflated tires. And blowouts came from underinflated ones. No?
Stallion said:Well less psi is lower milage because the lower the psi the smaller the circumference of the tire. Therefore same amount of revolutions = less miles = less mpg. That's my guess.
