Tire Pressure
  • Thread starter Thread starter 81kix
8
81kix
This may sound dumb...But I need to know the right amount of pressure in the tires when they are cold. ;shrug
Front tires are: 235/70/15
Backs are: 255/70/15
Thanks :s
i don't know what your set up is, the type of driving you like or brand and model tires you're running. tire pressure makes a big difference in cornering, drag racing and most of all ride quality. running 25 psi in the front and 20 in the rear is a good place to start. some tires have stiff sidewalls and require less pressure, while others are soft sides and need high psi. some people run 3/4 of the max pressure that is written on the side wall, experiment with the pressures and see what you like, Brian
