Heidi
tell him to be glad you are not asking him to overhaul the engine
Maineshark
Thats what I thought . I figured that the runout would have to be corrected by turning the rotor. and you are right about turning the rotor on the hub , The manual says " Due to the close tolerances involved, it is not recamended that the front hub and disc be machined or serviced separtely "
Wayne
I couldent figure why other cars run just fine with a bit of wobbel (rotor Runout) but the Vette just has fits !. Thanks for leting me know about the piston diferences .
Right now I plan on buying a stock rotor/calaper. as well as seals bearings,and new hose. this will get me on the rodad for the least $.
When I asked the parts guy if he had dial indicator that would measure rotor runout he gave me a blank look
I know what I need is just a regualr dial indicator they make them in a kit with diferent arm lengths .
I allso had a charging problem . I found a broken wire , It was a tough one to find as it was an open inside the insulation . I think that the factory screwed it up when they made the car as the open was inside the plastic channel , What I found was the red charging wire from the battery was red then it went into the black plastic split channel where it was crimped to a green solid conductor wire !!! then it was cripmped later on to a red wire where it was connected to the alt.
Anyway it is charging now so all is well.
I will post some pictures soon as I can. Thanks again all !!
Earl
