V
Vette66AirCoupe
RE: '66 Big Block, with A/C.
On the way home from a show on Sunday my nose was suddenly assaulted by the dreaded heavy smell of anti-freeze, and I do mean suddenly! Of course this had to happen on top of the Delaware Memorial Bridge! I thought for sure I had a major leak so I drifted down to the toll booth watching the temperature gauge like a hawk as well as the windshield for some tell tale steam. Nothing. I decided to press on and made it several miles to home without overheating, smelling anti-freeze all the way. When I got home there were droplets of anti-freeze on the engine and the underside of the hood but no dripping or hissing. I let it sit and came back a half hour later. No drips. Took the cap off and the anti-freeze level was about 3 inches from the top. Today I got my hands on a pressure tester and pumped the system up. I heard hissing at the top hose connection to the radiator. I tightened the clamp and the hissing stopped. So far so good. I added some water, maybe a half pint or so, to get the level up to about 2 inches from the neck which is where it always had seemed to be in the past. Now here is where my concern comes in. The pressure tester indictates a slow but steady drop in pressure from the 15lb index mark I pumped it up to with the engine off. So I started the engine to see if I would gain pressure quickly with it running. I let it run till warm and witnessed a slight gain in pressure but nothing radical, just a slow gain that you would expect with the warming of the engine. The pressure rose to about 22 lbs. at which time I shut the engine down. It had reached normal operating temperature. It sat for 5 minutes while I stuck my head everywhere but up the sidepipes listening and looking. Nothing. No foam on the dipstick either. Where in the hell is the pressure I'm puming into the system leaking out? It's really two different issues. #1 is where did the coolant come from under the hood? I'm hoping that was just the result of the loose clamp. #2 is where is the pressure going? If I see no external leaks, don't have sudden pressure gain in the cooling system when it's running and have no apparent evidence of anti-freeze in the oil can I rule out a head gasket problem? Oh, and the cap tested at 15 lbs and held like a rock so I'm sure the tester itself is not leaking. Anybody have any ideas? :confused
