taller said:
I would like to adjust the toe-in 1965 vette 327. The top of my tire is about 1" in at the top if you put a 24" level on it. If i understand the shop manual right it should have about 3/8" inward at the top. Is this correct. Also when I loosen the clamp bolt at eaach tie rod do I need to loosen both the clamps or just one? Or this this a adjustment that should be done at a shop?
when I had to get a new alignment on my '65 a few weeks back JohnZ suggested the following:
REAR:
zero to 1/2-degree negative camber, and 1/16" total toe-in, split equally across the thrust centerline (1/32" per side, exactly).
***Rear toe is the most critical setting on the whole car, particularly getting it evenly split to both sides across the thrust centerline.
USE SLOT SHIMS, NOT HOLE SHIMS!!!
FRONT:
zero camber, 2.5 degrees positive caster, and zero-to-1/16" total toe-in.
Note: on the caster, 2.5 is perfect for good tracking and returnability but increases static steering effort. 1.5 – 1.75 is a better setting with manual steering.
I would suggest taking it to a good alignment shop that has experience and knowedge on these older cars. Their machines can measure the proper settings a lot more precisely than you can.
