Tommorrow's projects
81 Corvette
Toledo
1981 Pearl White
find that damn ticking sound. Not sure if its a rocker or maybe an exaust leak. I just hoping its not a piston slapping a valve.
and even worse, figure out why my passenger door all of a sudden decided that it doesn't want to open from either inside or out. :ugh I've got an extra set of locks, so i may just change it out
Hello 81 Corvette,
I had a similar problem with the passenger door on my 78. The door latch had gotten gummed up over the years and froze up with the door latched closed. I ended up tearing off my inside door cover to get to the door latch to get the door open. What I found was that the grease in the latch had turned to varnish and froze up the latch. I soaked it in carb cleaner for a few days and it worked like new. Just lubed it up with white litium grease and it works like new. Good luck with your car.
Regards,
Cal
81 Corvette said:
..... and even worse, figure out why my passenger door all of a sudden decided that it doesn't want to open from either inside or out. :ugh I've got an extra set of locks, so i may just change it out
Had same problem with DRIVER-side door of my '82 a few times in '02, but it resolved itself:
it happened again this October, while at a local shopping center, so my G/F had to slide-over the console/shifter to play with the inside release while I worked from the outside.....
(Luckily, she had worn a very short skirt that day, and watching her climb-around the interior made it worth-while!!!!! ;) )
I called the local Corvette shop, and he advised us to apply some Liquid Wrench/Fast Break-type solvent into the rear of the door:
back into the store we went, buying a spray-can of WD-40, and it quickly de-gunked the residue on the latch, and the door opened with-in a few minutes.
The Corvette-guru says it is fairly common on C3s, and that spraying the latch-mechanism often may keep it this from happening again.
We now keep a full can of WD-40, AND a short skirt, in the cargo-hold of the '82 at all times.
:D
:D
I wonder if I could get my wife to slide over the shifter and play with the inside release while I work it from the outside?
If she has nice legs and wears a short skirt and heels.....
it'll change your impression of a K-Mart parking lot forever!
:upthumbs
turns out the door was just frozen shut from some rain the other night. :L
still can't find the ticking. sounds like its coming from teh driver side, so i pulled the valve cover and the rockers were fine. I found some loose header bolts, so i tighted them back up.
when listening from the top of the motor it sounds ok, but when you put your head down by the gill, it seems more noticable.:confused
what could make a tick besides a rocker and exaust?
If you can better hear-it at the fender gill, could it be manifold-to-exhaust pipe leak?
wrist-pin.....
hmm, could a fuel pump going south make a ticking sound?
like i said before, i haven't been able to isolate the tick yet, but my fuel pump went out this morning. :mad:
i had no idea it had an issue, but it started puking gas out of two small holes on the sides near the top.
if its not u joints, its fuel pumps :crazy:
I just hope she survives until september so i can get a real daily driver and i can tear off the body and start building her from the ground up.
Yes, a fuel pump can sound exactly like a lifter. If it's leaking gas out the vents it is also leaking into the engine.
Mike
thanks for the info Mike....
it sounded nearly identical to a lifter...
i'll get an oil change done as well
