Space Cowboy
- Joined
- Oct 8, 2003
- Messages
- 408
- Location
- Houston Texas
- Corvette
- 1968 Convertible - Candy Apple - 427/475+
Can an engine run too cold that it basically causes it to die while driving it?
This past weekend... I took my 68 w/427 out for a test drive after doing some work on it. The work did involve the dual-fan system. The water temp never got over 155 degrees according to the guage. After driving it a bit, it acting like it was missing heavily or like the engine was loading up. Then it finally died. After rolling to a stop, it started up right away. As soon as I got into 2nd or 3rd gear it did the same thing again, over and over. I limped all the way home like that. Luckily I was only about 6 miles away.
Another item of info... because of the cooling issues I was originally having, I removed the thermostat an left a constrictor in for reduce the water flow. If I put in a 180 degree thermostat, would this resolve this issue with the engine dying.
