1
1978L48jafo
I am looking for some advise on a torque converter for a TH350. My engine is built and still on the stand. I just put new seals in the transmission and cleaned it up. There is a wear line on the shaft of the converter. Not bad you can just barely feel it. My concern is that this car leaked everything I hate to reuse the old converter and have a leak.
I also don't quite understand the stall ratings. The motor is build with 9.5:1 Crane energizer cam, roller rockers, aluminum intake, and HEI performance chip. My vet will never see the drag strip but I do like a bit of performance.
Can I safely use emery cloth on the worn area? Or which converter is recommended for my situation? I am looking at the summit 1500-1900 rpm stall at the moment.
John
John
"CORVETTE" AMERICA'S ONLY TRUE SPORTS CAR!
