torque setting needed on caliper bolts
74bigblock
Barrington, IL
2008 Z06
Can someone kindly look up what I should torque my Caliper Mounting Bolts down to when I replace them? I bought the set for all 4 corners, and will replace all 8 bolts. I've got a '74 454.
Thanks!
My 74 asembly manual says. No less thah 60 ft-lbs. and no more than 80 ft-lbs. I would use 70 ft-lbs. The front and the back are the same number.
Caliper mounting bolts: 70 ft lbs
Phil
Thanks all!!! VROOOM.... VROOOOM VROOOOOM!
