larry bud
Well, this one had me stumped for quite a while. Was getting a lean code (code 44) on an '86. Not too many mods, fuel regulator, breathable exhaust, cam. When I would get the code, the motor would burp and churn like it was about to throw up. The code would come and and off while driving. Sometimes I'd go 2 or 3 days without any lights, car would work great. Then the next time I'd start it, it'd go haywire.
Started with the O2 sensor, as the wire going to it looked pretty bad. Probably was time for a new sensor anyway. No luck. Then I checked for vacuum leaks, and found the IAC was not tightened all the way. Then the exhaust at the manifold was loose. What the hell, did someone come in over the winter an loosen all my stuff on the car!!!?!?!
Replaced the plus, cap, rotor (which the center conductor actually had a hole worn through it). So tonight, I thought I had it solved. Figured the vaccum leak was doing it, although that still didn't explain the intermittent nature of it. I had thought all along: electrical. It's just the nature of the beast.
So I was going to go out tonight, and a couple miles down the road, engine light, and the car died on me. First time that's happened. Coasted into a side street, messed around under the hood in the dark wiggling wires, etc. Car finally started, and I limped home.
I'm in the garage, the car sounds like it's on its death bed, and I notice the cooling fan relay clicking on and off. That's strange, it should be on 100% of the time... Turn the motor off, and it sounded like everything electrical under my hood was clicking on and off! Nearly every relay AND INJECTOR. Aha! There's only one thing that controls the injectors: the computer!
Pulled the computer, wiggled the wires around, no luck. Pulled the chip and, viola! The clicking stopped. Put the chip back in, and as I wiggled the chip back and forth, the clicking under the hood would sometime start, sometimes stop. I thought it was a broken trace on the board, but I happened to still have my stock chip from 10 years ago. Plugged it in. NO CLICKING. It was making solid contact. I've got a GD bad computer chip! I don't know if it's just not making good contact anymore (I've sprayed it out and will try it later), or if the chip itself has gone bad. Not very typical for an IC to go haywire, though. I took a look at the solder joints on it, and they look fine. Almost as if the power to the chip was intermittent, since ALL the injectors were clicking on and off....
So, I put the old chip in, the car started right up, drove it around for a while and no engine lights (knock on fiberglass). We'll see what happens after it cools down overnight. Hopefully that's all it was!
