M
MLGower
I've been considering putting a TPI fuel injection unit into my '78 and wondered about a few things. I'm hoping someone out there has done this in California and can answer a few questions.
1. What about the Smog Pump? Do I get to throw it away, or do I have to keep it?
2. What's the best solution for Fuel lines from the tank on the C3?
3. Any Suggestions on the fuel Pump? I'm planning on adding an external pump, not an in-the-tank type.
4. Has anyone used a TPI from a Vette? Or is it better to go with one from another car like a Camaro ot TA?
5. Wiring Harness....Should I use one from a donor, or is there a company out there that makes one?
6. Can I adapt a serpintine belt system from one of the newer motors? Did they use the serpintine on the 86 Vette? Other than having to replace the water pump, is there anything else I need to know about that?
7. What's a real cost estimate on this?
8. Will I have any problems with Smog in Cali?
Getting the TPI setup isn't a problem (Tons of them on Ebay and in the junk yards). What worries me are all the little details that can turn this into a nightmare.
Thanks in Advance!!!!
Michael
Michael
