Just like the title says, what is the difference between them, and what one is the best to get? Also can you use SLP runners with a Superram, or do you have to have all of the accel parts for it to work ie. the runners and the acell plenum?
Vettefan87 said:Just like the title says, what is the difference between them, and what one is the best to get? Also can you use SLP runners with a Superram, or do you have to have all of the accel parts for it to work ie. the runners and the acell plenum?
AdvancedAutoCC said:I should clarify matters...
The Superram base with SLP runners and the OEM plenum (ported), rather than the SR upper plenum that has its own unique runners. Sorry for any confusion.
vader86 said:The Edelbrock and TPIS TPI intake base are both made by Edelbrock. TPIS does go one step further and port matches all the entries and exits on the manifold and the others do not. Accel makes their own TPI intake base.
TPiS runners=AS&M runners, AS&M makes them both.
